Nordea
SE
Last activity: 5 Jan 2023 7:57 EST
Date Format Changes back to US format when using On-Change Event
We are using pega v8.6.3 and On-change event followed by Refresh section keeping applicability in Editable mode changes the date to default US format and it only gets changed to desired format when I click outside the date control. Changing the applicability mode to Read-only solves the issue and date format is same as the one mentioned in the presentation tab.
The issue can also be fixed when we use on-click event instead of on-change regardless of the applicability mode.
I want to understand what is different in first scenario and why Pega is changing the date to US format. my operator locale settings, presentation mode on control is pointing to localized format.
***Edited by Moderator Marije to add Support Case Details***
