com.pega.dsm.dnode.api.StreamServiceException: Cannot add new node
Greetings. Hope you are well! We have a situation where the stream service does not start because of the exception
2022-11-18 11:36:04,746 [StreamServer.Default] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) ERROR - Cannot start service [StreamServer.Default]. Will retry in 180 seconds. Remaining attempts: 2 com.pega.dsm.dnode.api.StreamServiceException: Cannot add new node. Make sure all listed nodes are available or reattach the volume from one of these nodes to this node. We stop the instances every day and they get restarted next day. IP addresses are not static, and entries that are in pr_data_stream_* today may not be the same tomorrow. As a workaround, i have to truncate these tables every day and restart the ec2 instances however this cannot be the solution in Production environments. Is there any one who have had similar issue and found a resolution? I have raised an incident with Pega INC-249864 Any suggestions, please do let me know! Regards, Bharat
***Edited by Moderator Marissa to add Support Case Details***
