Robotics Tip of the day: Add items to the Property grid Standard view
Tip #38: Standard view on the Property grid contains the most frequently used properties for the selected control. If a property that you use frequently is not listed on Standard view by default you can add it to Standard view.
Switch to the Advanced view using the action menu, then right-click the property you want to add to Standard view and select Add to standard view. When you switch back to Standard view, the property will be visible. When the property is no longer needed regularly, you can right-click it and select Remove from standard view.
Note: Click here to see the latest Tip of the Day and a list of all prior tips.
