LTIMindtree
SA
Last activity: 6 Sep 2022 8:21 EDT
How to RESUME the Upgrade (Major / Minor / Patch) If failed during SQL Statements Execution
Issue Description:
Below error is one of the sample issue during the Upgrade script execution and is common to occur while executing the SQL statements. During the such cases i.e..
Issue Description:
2022-09-05 13:29:19,950 ( SQLLoaderInternal) WARNING - Statement: ALTER TABLE pega_cs_data.pr_data [java] ADD CONSTRAINT "pr_data_pk" PRIMARY KEY [java] ( [java] "pzinskey" [java] ) [java] 2022-09-05 13:29:19,951 ( SQLLoaderInternal) WARNING - [java] ******************************************************************************** [java] [java] Encountered a SQL Exception, clean schema before running again. [java] [java] ******************************************************************************** [java] Exception in thread "main" com.pega.pegarules.install.SQLLoaderException: Error executing SQL statements [java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:81) [java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:66) [java] Caused by: org.postgresql.util.PSQLException: ERROR: could not create unique index "pr_data_pk" [java] Detail: Key (pzinskey)=(DATA-ADMIN-JOBSCHEDULER-EXECUTION PZRULEQUEUEITEMPROCESSOR) is duplicated. [java] at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2552) [java] at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2284) [java] at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:322) [java] at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:481) [java] at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:401) [java] at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:322) [java] at org.postgresql.jdbc.PgStatement.executeCachedSql(PgStatement.java:308) [java] at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:284) [java] at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:279) [java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:160) [java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:119) [java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:99) [java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:78) [java] ...
