Annotation processing got disabled, since it requires a 1.6 compliant JVM
Hi all,
Did any one came across the below issue ?
This record has 1 error(s) in 1 place(s) .
Test compilation failed: Annotation processing got disabled, since it requires a 1.6 compliant JVM
Issue come from a section where we have specified on the presentation tab to use a currency symbol. Once the symbol is removed, no issues with the compilation. And section will be displayed normally on the UI.
Below configuration works without an issue on our lower environment and when the code is promoted to higher environment below issue is seen.
Thank you,
