CBA
Last activity: 31 May 2022 11:50 EDT
Jar import is not working for size more than 1 mb using prpcutils script
Getting connection reset error while jar import which is having size more than 1mb. java] 06:18:02.842 [pool-2-thread-1] INFO [.pegarules.serviceclient.rest.RestClient] - test2: Adding parameters {jsonBody={"artifactType":"","codesetVersion":"06-01-01","compileLibraries":"true","commitRate":"100","codesetName":"Customer","bypassSchemaChangesToDescendantTables":"false","bypassSchema":"","preferencespath":"","archivePath":"","repositoryName":"","bypassInstanceMigration":"false","existingInstances":"skip","nofailonerror":"false","mode":"import","preserveOrder":"false","async":"false","skipBackup":"false","allowImportWithMissingDependencies":"false","insecureOperators":"","bypassColumnPopulation":"false","importFromRepository":"false","allowInheritedConnections":"false"}} [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http:// Proprietary information hidden:8080: Connection reset by peer [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: Retrying request to {}->http:// Proprietary information hidden:8080 [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http:// Proprietary information hidden:8080: Connection reset by peer [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: Retrying request to {}->http:// Proprietary information hidden:8080 [java] 06:18:02.994 [main] INFO [viceclient.requestmanager.RequestManager] - Request on system test2 failed [java] 2022-05-26 06:18:02,997 main INFO sun.reflect.Reflection.getCallerClass is not supported. ReflectionUtil.getCallerClass will be much slower due to this. java.lang.ClassNotFoundException: sun.reflect.Reflection [java] at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:636) [java] at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:182) [java] at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:519)
***Edited by Moderator Marije to change Content Type from Discussion to Question; added capability tags***
ING Bank N.V.
@manikantap6884 Any reason while prpcUtil is being used for this ? PEGA OOTB Import mechanism usually supports files of upto 25MB in size during imports.
Accenture
@manikantap6884 Hi, Greetings. looking at the error, it is complaining on a class not found. If possible, try importing via Designer Studio as suggested by @VTALUKDAR , if you need this via prpcUtils, please post the complete stack trace.
Bharat
CBA
Hi @KOMARINA and @VTALUKDAR ,
Please find the below stack trace. This error is only for the jar's size more than 1 mb. Size less than 1mb is processing without errors.
-init: [echo] ****************************************************************** [echo] Build date : ${pegaBuildDate.value} [echo] Pega7 platform version : 8.3.2 [echo] ****************************************************************** [delete] Deleting directory /home/utils/generated [mkdir] Created dir: /home/utils/generated [pega:propertyparser] Reading Properties from: /home/utils/prpcServiceUtils.properties [pega:propertyparser] expose.startDate= [pega:propertyparser] import.bypassSchema= [pega:propertyparser] expose.excludedClasses= [pega:propertyparser] hotfix.async=true [pega:propertyparser] import.nofailonerror=false [pega:propertyparser] import.bypassSchemaChangesToDescendantTables=false [pega:propertyparser] expose.endKey= [pega:propertyparser] expose.endDate= [pega:propertyparser] import.mode=import [pega:propertyparser] import.allowImportWithMissingDependencies=false [pega:propertyparser] rollback.async=true [pega:propertyparser] pega.rest.proxy.password=***** [pega:propertyparser] pega.rest.password=***** [pega:propertyparser] pega.rest.response.type=json [pega:propertyparser] rollback.action=SystemRollback [pega:propertyparser] import.bypassColumnPopulation=false [pega:propertyparser] pega.rest.proxy.workstation= [pega:propertyparser] export.productName= [pega:propertyparser] pega.rest.proxy.port= [pega:propertyparser] export.exportToRepository=false [pega:propertyparser] export.repositoryName= [pega:propertyparser] hotfix.catalogPath= [pega:propertyparser] import.compileLibraries=true [pega:propertyparser] import.codesetVersion=06-01-01 [pega:propertyparser] export.applicationName= [pega:propertyparser] import.commitRate=100 [pega:propertyparser] export.applicationVersion= [pega:propertyparser] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash> [pega:propertyparser] expose.includedClasses= [pega:propertyparser] import.allowInheritedConnections=false [pega:propertyparser] getstatus.jobID= [pega:propertyparser] pega.rest.proxy.domain= [pega:propertyparser] custom.jvm.args= [pega:propertyparser] import.skipBackup=false [pega:propertyparser] hotfix.bypassSchema=false [pega:propertyparser] manageRestorePoints.action= [pega:propertyparser] updateAccessGroup.groupList= [pega:propertyparser] user.temp.dir= [pega:propertyparser] expose.reindexType=nonpega [pega:propertyparser] import.archive.path= [pega:propertyparser] export.productVersion= [pega:propertyparser] import.importFromRepository=false [pega:propertyparser] import.archivePath= [pega:propertyparser] manageRestorePoints.restorePointLabel= [pega:propertyparser] updateDASS.filePath= [pega:propertyparser] updateAccessGroup.applicationName= [pega:propertyparser] expose.reindex=true [pega:propertyparser] import.preserveOrder=false [pega:propertyparser] export.archiveName= [pega:propertyparser] rollback.restorePointName= [pega:propertyparser] hotfix.force=false [pega:propertyparser] export.branchAppContext= [pega:propertyparser] hotfix.operation= [pega:propertyparser] getstatus.operationName= [pega:propertyparser] expose.startKey= [pega:propertyparser] hotfix.dlFilePath= [pega:propertyparser] manageRestorePoints.restorePointName= [pega:propertyparser] import.async=true [pega:propertyparser] expose.numOfThreads=1 [pega:propertyparser] rollback.downloadLogToFile=true [pega:propertyparser] import.codesetName=Customer [pega:propertyparser] export.branchName= [pega:propertyparser] expose.commitRate=100 [pega:propertyparser] import.repositoryName= [pega:propertyparser] import.artifactType= [pega:propertyparser] expose.includeDescendents=true [pega:propertyparser] import.preferencespath= [pega:propertyparser] pega.rest.proxy.username= [pega:propertyparser] expose.async=true [pega:propertyparser] pega.rest.proxy.host= [pega:propertyparser] expose.excludeDescendents=true [pega:propertyparser] updateAccessGroup.applicationVersion= [pega:propertyparser] import.bypassInstanceMigration=false [pega:propertyparser] import.existingInstances=skip [pega:propertyparser] pega.rest.username= [pega:propertyparser] import.insecureOperators= [pega:propertyparser] export.async=true [mkdir] Created dir: /tmp/PegaInstallTemp-31-May-2022-06.18.01 [pega:hasenoughspace] Found 9881640KB of free space on '/tmp' [echo] *** JVM Arguments -Xmx1280m -Dlog4j.configurationFile=file:///%2Fhome%2Fxxx%2Ftemp%2FPRPC%2FprpcServiceUtils83%2Fscripts%2Flib%2Flog4j2.xml -Dlogfile.timestamp=May-31-2022-06-17-59 ***
-processInstances: [echo] Performing import on multiple instance(s) [pega:echoargline] arg line : -action import -propFileDir /home/utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir /tmp/PegaInstallTemp-31-May-2022-06.18.01 -artifactsDir /home/user/temp/PRPC/jar -processFailStrategy FAIL_PROCESS_ON_SINGLE_SYSTEM_FAILURE [echo] Reading connection information from /home/user/temp/PRPC/test_import.properties [pega:propertyfilegenerator] Systems Configured [pega:propertyfilegenerator] test [pega:propertyfilegenerator] Generated /home/utils/generated/test.prpcServiceUtils.properties for system test with properties: [pega:propertyfilegenerator] expose.startDate= [pega:propertyfilegenerator] import.bypassSchema= [pega:propertyfilegenerator] expose.excludedClasses= [pega:propertyfilegenerator] hotfix.async=true [pega:propertyfilegenerator] import.nofailonerror=false [pega:propertyfilegenerator] import.bypassSchemaChangesToDescendantTables=false [pega:propertyfilegenerator] expose.endKey= [pega:propertyfilegenerator] expose.endDate= [pega:propertyfilegenerator] import.mode=import [pega:propertyfilegenerator] import.allowImportWithMissingDependencies=false [pega:propertyfilegenerator] rollback.async=true [pega:propertyfilegenerator] pega.rest.proxy.password=***** [pega:propertyfilegenerator] pega.rest.password=***** [pega:propertyfilegenerator] pega.rest.response.type=json [pega:propertyfilegenerator] rollback.action=SystemRollback [pega:propertyfilegenerator] import.bypassColumnPopulation=false [pega:propertyfilegenerator] pega.rest.proxy.workstation= [pega:propertyfilegenerator] export.productName= [pega:propertyfilegenerator] pega.rest.proxy.port= [pega:propertyfilegenerator] export.exportToRepository=false [pega:propertyfilegenerator] export.repositoryName= [pega:propertyfilegenerator] hotfix.catalogPath= [pega:propertyfilegenerator] import.compileLibraries=true [pega:propertyfilegenerator] import.codesetVersion=06-01-01 [pega:propertyfilegenerator] export.applicationName= [pega:propertyfilegenerator] import.commitRate=100 [pega:propertyfilegenerator] export.applicationVersion= [pega:propertyfilegenerator] pega.rest.server.url=http:// Proprietary information hidden:8080/prweb/PRRestService/ [pega:propertyfilegenerator] expose.includedClasses= [pega:propertyfilegenerator] import.allowInheritedConnections=false [pega:propertyfilegenerator] getstatus.jobID= [pega:propertyfilegenerator] pega.rest.proxy.domain= [pega:propertyfilegenerator] custom.jvm.args= [pega:propertyfilegenerator] import.skipBackup=false [pega:propertyfilegenerator] hotfix.bypassSchema=false [pega:propertyfilegenerator] manageRestorePoints.action= [pega:propertyfilegenerator] updateAccessGroup.groupList= [pega:propertyfilegenerator] user.temp.dir= [pega:propertyfilegenerator] expose.reindexType=nonpega [pega:propertyfilegenerator] import.archive.path=/home/user/temp/PRPC/jar/ [pega:propertyfilegenerator] export.productVersion= [pega:propertyfilegenerator] import.importFromRepository=false [pega:propertyfilegenerator] import.archivePath= [pega:propertyfilegenerator] manageRestorePoints.restorePointLabel= [pega:propertyfilegenerator] updateDASS.filePath= [pega:propertyfilegenerator] updateAccessGroup.applicationName= [pega:propertyfilegenerator] expose.reindex=true [pega:propertyfilegenerator] import.preserveOrder=false [pega:propertyfilegenerator] export.archiveName= [pega:propertyfilegenerator] rollback.restorePointName= [pega:propertyfilegenerator] hotfix.force=false [pega:propertyfilegenerator] export.branchAppContext= [pega:propertyfilegenerator] hotfix.operation= [pega:propertyfilegenerator] getstatus.operationName= [pega:propertyfilegenerator] expose.startKey= [pega:propertyfilegenerator] hotfix.dlFilePath= [pega:propertyfilegenerator] manageRestorePoints.restorePointName= [pega:propertyfilegenerator] import.async=false [pega:propertyfilegenerator] expose.numOfThreads=1 [pega:propertyfilegenerator] rollback.downloadLogToFile=true [pega:propertyfilegenerator] import.codesetName=Customer [pega:propertyfilegenerator] export.branchName= [pega:propertyfilegenerator] expose.commitRate=100 [pega:propertyfilegenerator] import.repositoryName= [pega:propertyfilegenerator] import.artifactType= [pega:propertyfilegenerator] expose.includeDescendents=true [pega:propertyfilegenerator] import.preferencespath= [pega:propertyfilegenerator] pega.rest.proxy.username= [pega:propertyfilegenerator] expose.async=true [pega:propertyfilegenerator] pega.rest.proxy.host= [pega:propertyfilegenerator] expose.excludeDescendents=true [pega:propertyfilegenerator] updateAccessGroup.applicationVersion= [pega:propertyfilegenerator] import.bypassInstanceMigration=false [pega:propertyfilegenerator] import.existingInstances=skip [pega:propertyfilegenerator] pega.rest.username=TEST [pega:propertyfilegenerator] import.insecureOperators= [pega:propertyfilegenerator] export.async=true [pega:propertyfilegenerator]
_callService: [java] 06:18:02.406 [main] INFO [a.pegarules.serviceclient.ClientSettings] - -action import -propFileDir /home/utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir /tmp/PegaInstallTemp-31-May-2022-06.18.01 -artifactsDir /home/user/temp/PRPC/jar -processFailStrategy FAIL_PROCESS_ON_SINGLE_SYSTEM_FAILURE [java] 06:18:02.410 [main] INFO [a.pegarules.serviceclient.ClientSettings] - Setting Thread Pool Size to default 5 [java] 06:18:02.411 [main] INFO [a.pegarules.serviceclient.ClientSettings] - Setting Request TimeOut to default 300 [java] 06:18:02.421 [main] INFO [.pega.pegarules.serviceclient.ClientMain] - Initializing client Current Operation = IMPORT; Thread Pool Size = 5; RequestTimeOut = 300; TemporaryDirectory = /tmp/PegaInstallTemp-31-May-2022-06.18.01; ProcessFailStrategy = FAIL_PROCESS_ON_SINGLE_SYSTEM_FAILURE [java] 06:18:02.423 [main] INFO [viceclient.requestmanager.RequestManager] - Initializing Request Manager [java] 06:18:02.424 [main] INFO [viceclient.requestmanager.RequestManager] - Initializing ExecutorService with pool size 5 [java] 06:18:02.427 [main] INFO [viceclient.requestmanager.RequestManager] - Performing IMPORT with params [System Name = test Parameters = {expose.startDate=, import.bypassSchema=, import.bypassSchemaChangesToDescendantTables=false, import.allowImportWithMissingDependencies=false, pega.rest.proxy.password=*****, pega.rest.response.type=json, rollback.action=SystemRollback, pega.rest.proxy.workstation=, export.exportToRepository=false, hotfix.catalogPath=, import.codesetVersion=06-01-01, export.applicationName=, import.commitRate=100, export.applicationVersion=, pega.rest.server.url=http:// Proprietary information hidden:8080/prweb/PRRestService/, hotfix.bypassSchema=false, manageRestorePoints.action=, updateAccessGroup.groupList=, user.temp.dir=, expose.reindexType=nonpega, import.archive.path=/home/user/temp/PRPC/jar/, export.productVersion=, import.importFromRepository=false, manageRestorePoints.restorePointLabel=, updateDASS.filePath=, expose.reindex=true, import.preserveOrder=false, hotfix.force=false, getstatus.operationName=, import.async=false, expose.commitRate=100, import.repositoryName=, import.preferencespath=, pega.rest.proxy.host=, updateAccessGroup.applicationVersion=, import.bypassInstanceMigration=false, import.existingInstances=skip, import.insecureOperators=, export.async=true, expose.excludedClasses=, hotfix.async=true, import.nofailonerror=false, expose.endKey=, expose.endDate=, import.mode=import, rollback.async=true, pega.rest.password=*****, import.bypassColumnPopulation=false, export.productName=, pega.rest.proxy.port=, export.repositoryName=, import.compileLibraries=true, expose.includedClasses=, import.allowInheritedConnections=false, getstatus.jobID=, pega.rest.proxy.domain=, custom.jvm.args=, import.skipBackup=false, import.archivePath=, updateAccessGroup.applicationName=, export.archiveName=, rollback.restorePointName=, export.branchAppContext=, hotfix.operation=, expose.startKey=, hotfix.dlFilePath=, manageRestorePoints.restorePointName=, expose.numOfThreads=1, rollback.downloadLogToFile=true, import.codesetName=Customer, export.branchName=, import.artifactType=, expose.includeDescendents=true, pega.rest.proxy.username=, expose.async=true, expose.excludeDescendents=true, pega.rest.username=TEST}] [java] 06:18:02.440 [pool-2-thread-1] INFO [eclient.operation.custom.ImportOperation] - test:Not a valid archive (zip/jar), hence excluding 'jobIds.txt [java] [java] 06:18:02.834 [pool-2-thread-1] INFO [.pegarules.serviceclient.rest.RestClient] - test: Attaching files [/home/user/temp/PRPC/jar/Rules_3rdMay.zip, /home/user/temp/PRPC/jar/Rules_3rdMay_smae.zip, /home/user/temp/PRPC/jar/Rules_3rdMay_trak.zip, /home/user/temp/PRPC/jar/Rules_3rdMay_ever.zip, /home/user/temp/PRPC/jar/Rules_RM_01.zip, /home/user/temp/PRPC/jar/Rules_13033.zip, /home/user/temp/PRPC/jar/Rules_25dd.zip, /home/user/temp/PRPC/jar/Rules_htk.zip, /home/user/temp/PRPC/jar/Rules_3rdMay_25.zip, /home/user/temp/PRPC/jar/Rules_3rdMay_26.zip, /home/user/temp/PRPC/jar/Rules_327.zip] [java] 06:18:02.842 [pool-2-thread-1] INFO [.pegarules.serviceclient.rest.RestClient] - test: Adding parameters {jsonBody={"artifactType":"","codesetVersion":"06-01-01","compileLibraries":"true","commitRate":"100","codesetName":"Customer","bypassSchemaChangesToDescendantTables":"false","bypassSchema":"","preferencespath":"","archivePath":"","repositoryName":"","bypassInstanceMigration":"false","existingInstances":"skip","nofailonerror":"false","mode":"import","preserveOrder":"false","async":"false","skipBackup":"false","allowImportWithMissingDependencies":"false","insecureOperators":"","bypassColumnPopulation":"false","importFromRepository":"false","allowInheritedConnections":"false"}} [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http:// Proprietary information hidden:8080: Connection reset by peer [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: Retrying request to {}->http:// Proprietary information hidden:8080 [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http:// Proprietary information hidden:8080: Connection reset by peer [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: Retrying request to {}->http:// Proprietary information hidden:8080 [java] 06:18:02.994 [main] INFO [viceclient.requestmanager.RequestManager] - Request on system test failed [java] 2022-05-26 06:18:02,997 main INFO sun.reflect.Reflection.getCallerClass is not supported. ReflectionUtil.getCallerClass will be much slower due to this. java.lang.ClassNotFoundException: sun.reflect.Reflection [java] at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:636) [java] at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:182) [java] at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:519) [java] at java.base/java.lang.Class.forName0(Native Method) [java] at java.base/java.lang.Class.forName(Class.java:375) [java] at org.apache.logging.log4j.util.LoaderUtil.loadClass(LoaderUtil.java:141) [java] at org.apache.logging.log4j.util.ReflectionUtil.<clinit>(ReflectionUtil.java:65) [java] at org.apache.logging.log4j.core.impl.ThrowableProxy.<init>(ThrowableProxy.java:137) [java] at org.apache.logging.log4j.core.impl.ThrowableProxy.<init>(ThrowableProxy.java:122) [java] at org.apache.logging.log4j.core.impl.MutableLogEvent.getThrownProxy(MutableLogEvent.java:338) [java] at org.apache.logging.log4j.core.pattern.ExtendedThrowablePatternConverter.format(ExtendedThrowablePatternConverter.java:63) [java] at org.apache.logging.log4j.core.pattern.PatternFormatter.format(PatternFormatter.java:38) [java] at org.apache.logging.log4j.core.layout.PatternLayout$PatternSerializer.toSerializable(PatternLayout.java:333) [java] at org.apache.logging.log4j.core.layout.PatternLayout.toText(PatternLayout.java:232) [java] at org.apache.logging.log4j.core.layout.PatternLayout.encode(PatternLayout.java:217) [java] at org.apache.logging.log4j.core.layout.PatternLayout.encode(PatternLayout.java:57) [java] at org.apache.logging.log4j.core.appender.AbstractOutputStreamAppender.directEncodeEvent(AbstractOutputStreamAppender.java:177) [java] at org.apache.logging.log4j.core.appender.AbstractOutputStreamAppender.tryAppend(AbstractOutputStreamAppender.java:170) [java] at org.apache.logging.log4j.core.appender.AbstractOutputStreamAppender.append(AbstractOutputStreamAppender.java:161) [java] at org.apache.logging.log4j.core.config.AppenderControl.tryCallAppender(AppenderControl.java:156) [java] at org.apache.logging.log4j.core.config.AppenderControl.callAppender0(AppenderControl.java:129) [java] at org.apache.logging.log4j.core.config.AppenderControl.callAppenderPreventRecursion(AppenderControl.java:120) [java] at org.apache.logging.log4j.core.config.AppenderControl.callAppender(AppenderControl.java:84) [java] at org.apache.logging.log4j.core.config.LoggerConfig.callAppenders(LoggerConfig.java:448) [java] at org.apache.logging.log4j.core.config.LoggerConfig.processLogEvent(LoggerConfig.java:433) [java] at org.apache.logging.log4j.core.config.LoggerConfig.log(LoggerConfig.java:417) [java] at org.apache.logging.log4j.core.config.LoggerConfig.log(LoggerConfig.java:403) [java] at org.apache.logging.log4j.core.config.AwaitCompletionReliabilityStrategy.log(AwaitCompletionReliabilityStrategy.java:63) [java] at org.apache.logging.log4j.core.Logger.logMessage(Logger.java:146) [java] at org.apache.logging.log4j.spi.AbstractLogger.logMessageSafely(AbstractLogger.java:2091) [java] at org.apache.logging.log4j.spi.AbstractLogger.logMessage(AbstractLogger.java:1988) [java] at org.apache.logging.log4j.spi.AbstractLogger.logIfEnabled(AbstractLogger.java:1960) [java] at org.apache.logging.log4j.spi.AbstractLogger.error(AbstractLogger.java:733) [java] at com.pega.pegarules.serviceclient.LogHelper.error(LogHelper.java:52) [java] at com.pega.pegarules.serviceclient.requestmanager.RequestManager.processResponse(RequestManager.java:172) [java] at com.pega.pegarules.serviceclient.requestmanager.RequestManager.doOperation(RequestManager.java:141) [java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:82) [java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:57) [java] [java] 06:18:02.995 [main] ERROR [viceclient.requestmanager.RequestManager] - Request on system test failed [java] java.util.concurrent.ExecutionException: com.pega.pegarules.serviceclient.exception.PRPCServiceException: java.net.SocketException: Connection reset by peer [java] at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?] [java] at java.util.concurrent.FutureTask.get(FutureTask.java:205) ~[?:?] [java] at com.pega.pegarules.serviceclient.requestmanager.RequestManager.processResponse(RequestManager.java:156) [prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.requestmanager.RequestManager.doOperation(RequestManager.java:141) [prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:82) [prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:57) [prdeploy.jar:0.0.1-SNAPSHOT] [java] Caused by: com.pega.pegarules.serviceclient.exception.PRPCServiceException: java.net.SocketException: Connection reset by peer [java] at com.pega.pegarules.serviceclient.rest.RestClient.sendRequest(RestClient.java:88) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.RestClient.sendRequest(RestClient.java:45) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.AbstractRestRequest.execute(AbstractRestRequest.java:57) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.AbstractRestRequest.execute(AbstractRestRequest.java:31) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.request.AbstractRequest.call(AbstractRequest.java:62) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.request.AbstractRequest.call(AbstractRequest.java:30) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[?:?] [java] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130) ~[?:?] [java] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630) ~[?:?] [java] at java.lang.Thread.run(Thread.java:831) ~[?:?] [java] Caused by: java.net.SocketException: Connection reset by peer [java] at sun.nio.ch.NioSocketImpl.implWrite(NioSocketImpl.java:420) ~[?:?] [java] at sun.nio.ch.NioSocketImpl.write(NioSocketImpl.java:440) ~[?:?] [java] at sun.nio.ch.NioSocketImpl$2.write(NioSocketImpl.java:826) ~[?:?] [java] at java.net.Socket$SocketOutputStream.write(Socket.java:1045) ~[?:?] [java] at org.apache.http.impl.io.SessionOutputBufferImpl.streamWrite(SessionOutputBufferImpl.java:126) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.impl.io.SessionOutputBufferImpl.flushBuffer(SessionOutputBufferImpl.java:138) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.impl.io.SessionOutputBufferImpl.write(SessionOutputBufferImpl.java:169) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.impl.io.ContentLengthOutputStream.write(ContentLengthOutputStream.java:115) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.entity.mime.content.FileBody.writeTo(FileBody.java:121) ~[httpmime-4.5.1.jar:4.5.1] [java] at org.apache.http.entity.mime.AbstractMultipartForm.doWriteTo(AbstractMultipartForm.java:134) ~[httpmime-4.5.1.jar:4.5.1] [java] at org.apache.http.entity.mime.AbstractMultipartForm.writeTo(AbstractMultipartForm.java:157) ~[httpmime-4.5.1.jar:4.5.1] [java] at org.apache.http.entity.mime.MultipartFormEntity.writeTo(MultipartFormEntity.java:103) ~[httpmime-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.DefaultBHttpClientConnection.sendRequestEntity(DefaultBHttpClientConnection.java:158) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.impl.conn.CPoolProxy.sendRequestEntity(CPoolProxy.java:162) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.protocol.HttpRequestExecutor.doSendRequest(HttpRequestExecutor.java:237) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:122) ~[httpcore-4.4.3.jar:4.4.3] [java] at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:271) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82) ~[httpclient-4.5.1.jar:4.5.1] [java] at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107) ~[httpclient-4.5.1.jar:4.5.1] [java] at com.pega.pegarules.serviceclient.rest.RestClient.doPost(RestClient.java:115) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.RestClient.sendRequest(RestClient.java:77) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.RestClient.sendRequest(RestClient.java:45) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.AbstractRestRequest.execute(AbstractRestRequest.java:57) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.rest.AbstractRestRequest.execute(AbstractRestRequest.java:31) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.request.AbstractRequest.call(AbstractRequest.java:62) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at com.pega.pegarules.serviceclient.request.AbstractRequest.call(AbstractRequest.java:30) ~[prdeploy.jar:0.0.1-SNAPSHOT] [java] at java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[?:?] [java] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130) ~[?:?] [java] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630) ~[?:?] [java] at java.lang.Thread.run(Thread.java:831) ~[?:?] [java] [java] FAILED JOBS [java] -------------------------------------------------------------------------------------------- [java] [java] System Name : test [java] Job ID : [java] Status : [java] Error Message : REQUEST_EXECUTION_ERROR com.pega.pegarules.serviceclient.exception.PRPCServiceException: java.net.SocketException: Connection reset by peer [java] -------------------------------------------------------------------------------------------- [java] 06:18:03.041 [main] INFO [viceclient.requestmanager.RequestManager] - Shutting down executor service [java] 06:18:03.041 [main] INFO [viceclient.requestmanager.RequestManager] - Executor Service shutdown completed [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http:// Proprietary information hidden:8080: Connection reset by peer [java] May 26, 2022 6:18:02 AM org.apache.http.impl.execchain.RetryExec execute [java] INFO: Retrying request to {}->http:// Proprietary information hidden:8080 [java] Exception in thread "main" Operation IMPORT failed on test, [java] at com.pega.pegarules.serviceclient.FailProcessOnSingleSystemFailure.reportStatus(FailProcessOnSingleSystemFailure.java:26) [java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:92) [java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:57)
BUILD FAILED /home/utils/prpcServiceUtilsWrapper.xml:180: The following error occurred while executing this line: /home/utils/prpcServiceUtilsWrapper.xml:197: Java returned: 1
Total time: 2 seconds Ant Process returned a non 0 value
