The application crashes
Can you help me please. The application crashes and gives the following error
2022-04-20 09:35:34,234 [or], Partitions=[11]] [ STANDARD] [ ] [ ] (ataflow.task.ExecutionDoneTask) ERROR - No nodes are processing the run [pzStandardProcessor] and its current status is [Resuming]. Setting it to Paused
2022-04-20 09:37:43,178 [Flow.Default-Pulse:0] [ STANDARD] [ ] [ ] (.DataFlowServicePulseOperation) ERROR - Error during while executing pulse task: rebalanceStreamableRunsWhenNotAllNodesAreProcessing
java.lang.IllegalStateException: Cannot resume run [pyProcessNotification] with status [Resuming]. Reason: Cannot transition run to Resuming
at com.pega.dsm.dnode.impl.dataflow.task.ResumeRunTask$ResumeTaskResult.generateException(ResumeRunTask.java:116) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.task.RebalanceRunTask.continueResume(RebalanceRunTask.java:160) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.task.RebalanceRunTask.continuePausing(RebalanceRunTask.java:149) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.task.RebalanceRunTask.doRebalance(RebalanceRunTask.java:112) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.task.RebalanceRunTask.rebalance(RebalanceRunTask.java:69) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.task.RebalanceRunTask.rebalance(RebalanceRunTask.java:54) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.DataFlowServicePulseOperation$6.execute(DataFlowServicePulseOperation.java:267) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.DataFlowServicePulseOperation$9.emit(DataFlowServicePulseOperation.java:308) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:338) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:40) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:102) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:91) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.api.prpc.service.ServiceManager$9.run(ServiceManager.java:439) ~[d-node-8.1.8-1032.jar:?]
at com.google.common.util.concurrent.MoreExecutors$ScheduledListeningDecorator$NeverSuccessfulListenableFutureTask.run(MoreExecutors.java:656) ~[guava-19.0.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_181]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_181]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_181]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_181]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_181]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_181]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:44) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:41) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:52) ~[d-node-8.1.8-1032.jar:?]
at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:109) ~[d-node-8.1.8-1032.jar:?]
I also have thousands of repetitions of this error
2022-04-20 18:18:55,323 [ PegaRULES-Batch-42] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) ERROR - Batch activity "Int-PegaCDH-Container.CreateAssociationsInIH" threw:
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:713) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:481) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:297) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:362) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1139) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1366) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1109) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:990) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:805) ~[prprivate.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_181]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_181]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
Caused by: com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'CREATEASSOCIATIONSINIH' that applies to 'Int-PegaCDH-Container'. There were 2 rules with this name in the rulebase, but none matched this request. The 2 rules named 'CREATEASSOCIATIONSINIH' defined in the rulebase are:
1 related to applies-to class 'Int-PegaCDH-Container', but were defined in rulesets which are not in your rulesetlist: 'PegaMKT-Engine:08-01-01'.
1 unrelated to applies-to class 'Int-PegaCDH-Container', for example: 'PegaMKT-'.
Current RulesetList:
Pega-ProcessCommander:08-01,
Pega-DeploymentDefaults:08-01,
Pega-DecisionScience:08-01,
Pega-DecisionArchitect:08-01,
Pega-LP-Mobile:08-01,
Pega-LP-ProcessAndRules:08-01,
Pega-LP-Integration:08-01,
Pega-LP-Reports:08-01,
Pega-LP-SystemSettings:08-01,
Pega-LP-UserInterface:08-01,
Pega-LP-OrgAndSecurity:08-01,
Pega-LP-DataModel:08-01,
Pega-LP-Application:08-01,
Pega-LP:08-01,
Pega-SystemOperations:08-01,
Pega-UpdateManager:08-01,
Pega-SecurityVA:08-01,
Pega-Feedback:08-01,
Pega-HealthCheck:08-01,
Pega-AutoTest:08-01,
Pega-AppDefinition:08-01,
Pega-ImportExport:08-01,
Pega-LocalizationTools:08-01,
Pega-RuleRefactoring:08-01,
Pega-ProcessArchitect:08-01,
Pega-Portlet:08-01,
Pega-Content:08-01,
Pega-BigData:08-01,
Pega-NLP:08-01,
Pega-DecisionEngine:08-01,
Pega-IntegrationArchitect:08-01,
Pega-SystemArchitect:08-01,
Pega-Desktop:08-01,
Pega-EndUserUI:08-01,
Pega-Survey:08-01,
Pega-Social:08-01,
Pega-SharedData:08-01,
Pega-API:08-01,
Pega-EventProcessing:08-01,
Pega-Reporting:08-01,
Pega-UIDesign:08-01,
Pega-Gadgets:08-01,
Pega-UIEngine:08-01,
Pega-ProcessEngine:08-01,
Pega-SearchEngine:08-01,
Pega-IntegrationEngine:08-01,
Pega-RulesEngine:08-01,
Pega-Engine:08-01,
PegaLegacyRules:01-01,
Pega-ProCom:08-01,
Pega-IntSvcs:08-01,
Pega-WB:08-01,
Pega-RULES:08-01
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolverImpl.throwDetailedRuleNotFoundException(VirtualTableResolverImpl.java:722) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolverImpl.resolveToCandidate(VirtualTableResolverImpl.java:426) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolverImpl.resolveToContainer(VirtualTableResolverImpl.java:379) ~[prprivate.jar:?]
at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolverImpl.resolveRule(VirtualTableResolverImpl.java:148) ~[prprivate.jar:?]
at com.pega.platform.executionengine.vtable.internal.VirtualTableNoChangeImpl.resolveRule(VirtualTableNoChangeImpl.java:322) ~[execution-engine.jar:?]
at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:597) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3540) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ~[prprivate.jar:?]
... 12 more
***Edited by Moderator Marije to add Support Case Details; update capability tags***
