Issue when moving Exposed Property to another environment
As part of one of the application Data pages, we created a report to feed it, this required exposing an embedded property ".RequestInformation.Category". Data page worked as expected in Dev environment (hosted on Pega Cloud). However, when we moved the product rule to Staging environment I noticed the exposed property was not optimized...
We created Product rule with class groups and DB tables (also affected Class instances), however the column category_1 which was created on Dev, does not get created in Staging. When we check the Modify Schema wizard, the number of columns in Staging (226) is different than in Dev (229).
I heard we can use prpcServiceUtils to expose columns, however I'm not sure how to use it in Pega Cloud.
I know there is a lot of exposed/optimized property questions already, and believe me I checked many of them, but still not sure how to resolve this...
Thanks for any help on this.
-Jose
