HCLTECH
HCLTECH
HCLTECH
Posted: Mar 14, 2022
Last activity: Mar 14, 2022
Last activity: 14 Mar 2022 12:37 EDT
Root exception Class: com.pega.pegarules.pub.clipboard.InvalidReferenceException Message: The reference ClipboardPage is not val
Root exception
Message: The reference ClipboardPage is not valid. Reason: FUAInstance-NullMyStepPage
How to fix the issue in 8.6.2
***Edited by Moderator Marije to change type from Pega Academy to Product***
@RajasekharN1860 please can you provide some context to your question?
Did you already check other forum questions?
Activity Property-Set: FUAInstance-NullMyStepPage
The reference <code block> is not valid. Reason: FUAInstance-NullMyStepPage
The reference local.formTypeLocal != @pxGetFormType(.pxObjClass) is not valid. Reason: FUAInstance-NullMyStepPage
Load Data-Page in activity , FUAInstance-NullMyStepPage
If suggestion in the above posts do not help you further:
Where does your user see this error?
What is the user doing at the time?
Is this a new updated system? Can you replicate this consistently?
Can you share the configuration of the rule or process activity causing this issue?
