Independent Financial
Last activity: 2 May 2022 1:57 EDT
Unable to Search for Mission called "data and integration foundation"
Mission: data and integration foundation
Earlier today, I was able to search for this mission but I was unable to load the Mission Test (it was stuck on "loading..." and would not update pages).
Now, I am unable to search for the mission overall. Can you look into this?
Updated: 2 May 2022 1:57 EDT
@LivyaP29 Hi Livya, this issue is resolved. We apologize for the inconvenience
@TonyB121 Hi Tony, it does seem to have gone missing from search results. I will investigate. Here is the direct link: https://academy.pega.com/mission/data-and-integration-foundation/v3
@eddie.jm Hi Eddie - thank you. The direct link works but now the original issue is back. When I select on the Mission Test and try to load the test, it gets stuck on "loading..."
@TonyB121 I was able to load the test, although it did seem a little slow. If you are on a VPN try disconnecting. fwiw, we just pushed an update to production so things might take a bit of time to settle down.
@TonyB121 Hi Tony, when I masquerade as you, the mission test loads for me
if you are on a VPN, try disconnecting.
let me know
UST Global
Hi ,
I'm not getting mission test for data integration mission in 8.6 version. Hence not able to mark as 100%.Please help.
I'm planning for cssa certification in 8.6
