Rabobank
Last activity: 6 Feb 2022 22:25 EST
How to add swipe actions if not listed in the app studio? The challenge says that a list would be available but found empty.
Updated: 6 Feb 2022 22:25 EST
@RamyaR31 Hi Ramya, I can confirm this issue is not reproducible from my end. It is less about the pc you are using and more about the network you are on. If you are on a VPN, disconnect from the VPN and make sure to clear your browser cache. It could also be a proxy server issue, so make sure to bypass any proxy servers. Finally, check firewall settings to confirm the Pega instance domain is not blocked.
@RamyaR31 Hi Ramya, we are aware of this issue and are working to resolve it as quickly as possible. I will update this post when a resolution is in place.
Updated: 6 Feb 2022 19:31 EST
Rabobank
@eddie.jm Thank you for the quick response . As I am not able to complete this challenge without this configuration , can you suggest any workaround ?
@RamyaR31 Hi Ramya, unfortunately, this is an auto-graded challenge and one of the checks is that you have enabled the left swipe action. I am so sorry. I will escalate this issue so we do not block your training.
@RamyaR31 Hi Ramya, disregard my previous response. I just disabled the check because it does not work. Resubmit your challenge for verification and let me know how you get along.
Ramya Rajendrababu
Rabobank
@eddie.jm Thank you!! I am able to complete the challenge. However, I am facing an issue with Calculating fields using decision table challenge. Can you please help? The system hangs on clicking the gear icon. I have tried multiple times and facing the same issue ?
@RamyaR31 Hi Ramya, this issue is usually caused by security settings on a corporate network or a VPN, or proxy server issue.
If you are on a VPN, try disconnecting from the VPN. If you are on a corporate network or proxy server, it could be the firewall/security settings - try attempting the challenge from a different network.
Rabobank
@eddie.jmtried both from my personal pc and work system and facing the same issue. May be will try after a while. In the meantime can you please check if this issue is not reproducible at your end? Appreciate the support. Thanks.
Ramya Rajendrababu
