Capgemini
BR
Last activity: 26 Jan 2022 11:54 EST
Data Page runs but does not display the results.
We perform the migration of our application from a Pega Cloud environment to the client's environment that is configured as OnPremisse, using the following structure:
TomCat 9 OpenJDK Proprietary information hidden+8 Sql Server 2019.
Access is used through a reverse proxy server that calls a Pega BackEnd server.
We verified that when performing the DataPage call, it is executed, but the results are not presented. This only happens with the Data Page. If we use it on a screen, the values are displayed on the screen, however, if we run the rule by hand, for example to do a unit test of the rule, it is not possible.
Any way to evaluate and try to solve the problem?
