com.pega.pegarules.pub.generator.RuleNotFoundException
Facing this issue in all environment for specific nodes.This is declare trigger activity and i have revalidated and saved this rule but thats not helping
Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'RELOADNBA' that applies to 'PegaCA-Work'. There were 10 rules with this name in the rulebase, but none matched this request. The 10 rules named 'RELOADNBA' defined in the rulebase are:1 related to applies-to class 'PegaCA-Work', but were defined in rulesets which are not in your rulesetlist: 'SA-Artifacts:08-01-01'.9 unrelated to applies-to class 'PegaCA-Work', for example: {PegaCRM-Work-Task-CustAct, PegaSocial-Message, PegaCRM-Work-SFA-Opportunity-Ind, PegaCRM-Entity-Contact, PegaCRM-Work-SFA-Lead, PegaCRM-Work-SFA-Opportunity}.Current RulesetList:Pega-ProcessCommander:08-04,Pega-DeploymentDefaults:08-04,Pega-DecisionScience:08-04,Pega-DecisionArchitect:08-04,Pega-LP-Mobile:08-04,Pega-LP-ProcessAndRules:08-04,Pega-LP-Integration:08-04,Pega-LP-Reports:08-04,Pega-LP-SystemSettings:08-04,Pega-LP-UserInterface:08-04,Pega-LP-OrgAndSecurity:08-04,Pega-LP-DataModel:08-04,Pega-LP-Application:08-04,Pega-LP:08-04,Pega-SystemOperations:08-04,Pega-UpdateManager:08-04,Pega-SecurityVA:08-04,Pega-Feedback:08-04,Pega-HealthCheck:08-04,Pega-AutoTest:08-04,Pega-AppDefinition:08-04,Pega-ImportExport:08-04,Pega-LocalizationTools:08-04,Pega-RuleRefactoring:08-04,Pega-ProcessArchitect:08-04,Pega-Portlet:08-04,Pega-Content:08-04,Pega-BigData:08-04,Pega-NLP:08-04,Pega-DecisionEngine:08-04,Pega-IntegrationArchitect:08-04,Pega-SystemArchitect:08-04,Pega-Desktop:08-04,Pega-EndUserUI:08-04,Pega-Survey:08-04,Pega-Social:08-04,Pega-SharedData:08-04,Pega-API:08-04,Pega-EventProcessing:08-04,Pega-Reporting:08-04,Pega-UIDesign:08-04,Pega-Gadgets:08-04,Pega-UIComponents:08-04,Pega-UIEngine:08-04,Pega-ProcessEngine:08-04,Pega-SearchEngine:08-04,Pega-IntegrationEngine:08-04,Pega-RulesEngine:08-04,Pega-Engine:08-04,PegaLegacyRules:01-01,Pega-ProCom:08-04,Pega-IntSvcs:08-04,Pega-WB:08-04,Pega-RULES:08-04 |
