Merging two separate Pega Applications into one application.
We are planning to merge two separate Pega applications which are Installed in two separate servers into a one infrastructure. Planning to merge/migrate Pega RULES and Peda DATA schemas. Planning to introduce a common application for enterprise layer and will be reused
Both the applications are in production and on same Pega version.
Have to migrate Data instances , Work Objects, Assignments , Attachments etc.. (Due to current Case volume Package Work Objects wizard may not be helpful)
Really appreciate if you could share any approaches or things to consider in merging applications.
