Optum Global Solutions
Last activity: 18 Nov 2021 10:34 EST
Is there a way to use configuration file component where the user can change the value outside the solution
I am trying to use the configuration component available in the robotics so as to avoid hard coded values for some attributes. Therefore, enable the runtime user to change the value in the config which the bot can use at runtime to read the updated values without actually making any code changes.
Any advice would be much appreciated.
Thank you,
Megha
