Is there a way to set timeout in DataSets of type database?
We are facing issues where the query run by data set is timing out and hence campaign run is failing. Is there a way to set timeout in DataSets of type database?
Exception:
Unable to query the database: code: 1013 SQLState: 72000 Message: ORA-01013: user requested cancel of current operation DatabaseException caused by prior exception: java.sql.SQLTimeoutException: ORA-01013: user requested cancel of current operation | SQL Code: 1013 | SQL State: 72000 From:
