Tech Mahindra
Last activity: 16 Nov 2021 18:35 EST
Error while generating segment SQL Trying to save an invalid page: page is not valid
I am getting the error while creating a new segment.
I have seen this article https://community.pega.com/support/support-articles/segment-creation-fails-generating-segment-sql-error. My customer table is in externalmkt schema which is in the same database. So this is not the issue. Is there any reason why this issue is coming?
Nizam
Tech Mahindra
Based on my analysis, this is failing to find the database in the below function. My db connection is good for externalmkt. Looks like I am missing something.
Database : Postgres
Innova Consulting
@VENKATESH GUDEENTI Any Luck? I have this error as well, I can see it on the tracer and on the UI
TPG Telecom
I am also facing the same issue with Pega CDH 8.6 version.
Any luck on how to get this resolved. From logs what i see it is looking for the table:-
externalmktdata.mktsegbatch1
Though class and database table records are added, but the table is not created in externalmktdata schema in postgres DB.
I too have only 1 DB.
Innova Consulting
@IpsitaS3do you have any when conditions in your activity, if any?
In my scenario- I had a when condition where I missed writing a jump condition.
let me know if that helped?
thanks
TPG Telecom
Hi @VENKATESH GUDEENTI/ @Nizam ,
I too am facing the same issue. Any luck to get this issue resolved. I see my table is getting created in rules schema instead of externalmktdata. I too am using postgres DB.
If i manually create the table in externalmktdata , then my segments gets created fine. But then that's a manual thing .
Any DSS setting that we need to use to get it resolved?
@IpsitaS3 Have you created a separate login user for ExternalMKTData schema and confirm if this username and password is configured correctly for the ExternalMKTData? Also are you using a JDBC URL or Configuration Preferences for ExternalMKTData?
Bharat Singh Rathore
TPG Telecom
The login user is postgres which is same for all schemas under the same database. I dont have a separate login user for externalmktdata.
I am using JDBC URL. I have configured the username and pwd in the DADN and have tested the connectivity as well.
When i manually create the segment table in externalmktdata, it executes successfully as well.
@IpsitaS3 I am guessing that the JDBC URL is missing the currentSchema parameter. The JDBC URL should look like this -
jdbc:postgresql://localhost:5432/mydatabase?currentSchema=externalmktdata
Please check if that is set and if not then set it and try.
Ipsita Saha KNS Dattabhishek Somyamay Chakravarty
TPG Telecom
