Evonsys
Last activity: 23 Apr 2021 13:38 EDT
Pega Robotics error while reading Etag
I am having an issue where after making all the changes to RuntimeConfig.xml; the file gets overridden after starting up the bots and default all the changes. Below are the error throws on logs. Appreciate if someone could help/give any guidance.
RoboticsApiHelper.RegisterRobot - Robot registration succeeded. Info | 09:23:09.099 PM | 1 | MTA | | | | Authenticated user WC42A10198QV00 Warning | 09:23:09.099 PM | 1 | MTA | OSS | | | Hash does not match local file 'C:\Users\VMUSER\AppData\Roaming\Pegasystems\RuntimeConfig.xml'. Warning | 09:23:09.099 PM | 1 | MTA | OSS | | | Error while reading Etag for file 'C:\Users\VMUSER\AppData\Roaming\Pegasystems\RuntimeConfig.xml', will request new file from server. Info | 09:23:09.617 PM | 1 | MTA | OSS | | | Cache for file 'C:\Users\VMUSER\AppData\Roaming\Pegasystems\RuntimeConfig.xml' did not match server configuration. Downloaded file from the server. Info | 09:23:09.617 PM | 1 | MTA | OSS | | | File 'C:\Users\VMUSER\AppData\Roaming\Pegasystems\RuntimeConfig.xml' successfully downloaded from server at '/PRRestService/robotics/v1/runtimeconfigs' on RobotManager server.
