Hoverstate
Last activity: 9 Mar 2021 8:54 EST
automation always hangs on waitforcreate after multiple successful loops
As title - I have an automation which loops through several forms and uses a waitforcreate to know when the form is loaded and to enter details. It works through several loops but hangs after 5-10 passes. It does not exit the false leg, as if it timed out failing to match, it simply hangs for 10+ minutes on that screen.
Here are surrounding logs, 410-01 line is immediately before the waitforcreate
Any suggestions why this may be happening?
