Capgemini
RO
Last activity: 8 Jul 2021 7:18 EDT
Error on Page-Copy after Apply-Parse-XML
We need to perform a Page-Copy after applying a parse XML. Although the Parse XML appears to execute correctly, we get the following error when the Page-Copy is called:
2021-02-19 12:19:49,768 [ttp-/ Proprietary information hidden:8443-11] [ STANDARD] [ ] [ BP:01.03.24] ( internal.mgmt.Executable) ERROR bpcls.uat.ro.cre.insim.biz| Proprietary information hidden [email protected] - Exception com.pega.pegarules.pub.clipboard.InvalidParameterException: cannot be null. Details: Invalid value for aValue passed to com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.add() at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.add(ClipboardPropertyBase.java:2447) at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.add(ClipboardPropertyBase.java:2442) at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.add(ClipboardPropertyBase.java:2438) at com.pega.pegarules.priv.integration.xml.ParseXMLSAXRuleWrapper.prPutAll(ParseXMLSAXRuleWrapper.java:3183) at com.pega.pegarules.priv.integration.xml.ParseXMLSAXRuleWrapper.prPutAll(ParseXMLSAXRuleWrapper.java:3130) at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.putAll(ClipboardPageImpl.java:2963) at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.putAll(ClipboardPageImpl.java:2840) at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.putAllAndReconcileRefProps(ClipboardPageImpl.java:2808) at com.pega.pegarules.data.internal.clipboard.ClipboardPageBase.putAll(ClipboardPageBase.java:1167) at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.putAll(ClipboardPageImpl.java:482) at com.pegarules.generated.activity.sh_action_loadt7979_old_5c4df00c4c21918c02ac07f045cef639.step5_3_circum0(sh_action_loadt7979_old_5c4df00c4c21918c02ac07f045cef639.java:758)
Can you help us understand what seems to be the issue?
Commenting out the Page-Copy method call makes the activity run successfully, but trying to access from clipboard the page on which Apply-Parse-XML was called results in the following error:
Thread Lock Message
InvalidParameter cannot be null aValue com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.add() |
with no additional error in the logs.
We're using Pega 7.1.8
Any help would be appreciated.
