Tech Mahindra
Last activity: 16 Feb 2021 16:07 EST
unable to access excel file from a particular location in user's machine as that excel file is not present in their system.
When I am using an Excel connector to replace records in a lookup table I am able to access the data but when I am deploying the code and the users run the same application they are getting error because the file is not present at their machine in that particular location. However I am able to deploy the file in deployment folder of user's machine also but before the file gets copied to required location it is giving error as "Error Initializing Design Component". Is there any way to use excel file in user's machine also so that they can access it from a particular location?
