SMS Data Products
Last activity: 20 Jan 2021 11:08 EST
Updating a Test Case
I am brand new to Pega. I created a test case under case type trying, and it doesn't do what I need it to do. No it seems that I can neither edit it nor delete. I've read a few other posts that seem to indicate that test cases that created with the automated test case generator can't be edited, and others that indicate it is a non-trivial exercies involving activity creation etc. to delete a test case. What is the simplest method to either update/edit my test case to do what I need it to do, or eliminate it so I can start over?
It is not clear on what you are trying to edit or the reference of test case generator.
If you are looking at PegaUnits, you can find info and best practices around them at https://collaborate.pega.com/discussion/pega-test-automation-features-best-practices-faq
