Evoke Technologies
PL
Last activity: 11 Dec 2023 9:07 EST
How to get the index of the property changed in Auditing which is inside a pagelist
Currently, I have overridden the OOTB pyTrackSecurityChanges activity and using Field values TrackSecurityChange_Add, TrackSecurityChange_Remove, and TrackSecurityChange_Chnage
and when a property value is changed, copying the Old Value, New Value, and PyLabel from the pyHistoryMemo in the Trigger activity and Saving those to Cutsom Data Table.
But my requirement is to track the Pagelist properties in a Table, and Audit every change on the fields, for example,
In the Table if User1 location value is changed, we should track and set in the Audit History Tab with Emp ID and filed changed with old & new values as below,
Please Suggest how to get the index/reference of the Pagelist property being changed ,if any existing OOTB Approach can be used or any other approach we can achieve this functionality.
Sagar
