Societe Generale Corporate & Investment Banking
FR
Last activity: 15 Sep 2020 3:38 EDT
Unable to use expression when map operator id from claim in OpenID authentication service
I currently use Pega Platform 8.3.
we have implemented an OpenID Connect SSO authentication service.
My problem is about Operator identification with claim info (I don't use operator provisioning).
Currently, claim data "sesame_id" is used to find the operator and it works:
Example: my operator identifier in Pega is "johan.grall" and sesame_id from claim is "johan.grall". Mapping works and I'm log with operator "johan.grall".
There is a new behavior to manage claim data "sesame_id" which contains a '-' character. In this case, the corresponding operator id in Pega contains a '_' character instead of '-'.
Example: my operator identifier in Pega is "johan_grall" and sesame_id from claim is "johan-grall"
I try to use an expression when mapping operator id but it doesn't work:
When I connect, error massage "Unable to execute OIDC flow : Unable to derive operator from IDToken" is displayed. No error message in log, even if I set "debug level" for OIDC logger.
I have tested several thing but same issue:
- {sesame_id} instead of sesame_id
- Use data page "D_pyUserInfoClaims" (but seems this data page use info from operator; means that operator should be identified before use this data page).
- Use "mapping" tab but mapping seems run after operator identification.
Do you have idea on why I'm not able to use expression to map operator id from claim ?
Johan
