SocketException while publishing to package server.
I have installed PackageServer on a local machine (Machine A), and have been trying to publish a package from DevStudio (on Machine B).
I am getting a SocketException, with MachineA refusing the connection.
Machine A: Win10, PackageServer version Proprietary information hidden
Machine B: Win7, Dev Studio version Proprietary information hidden
The ping from Machine B to Machine A, and vice versa is successful.
The error log is as follows:
DEBUG | 2020-07-20 17:45:52,266 | 1 | 1 | 4844 | STA | Shell | | | Project 'Trial\Trial.osproj' build state changing to Default and status of True DEBUG | 2020-07-20 17:45:52,329 | 1 | 1 | 4844 | STA | Listener | | | Resolver: assembly 'Trial' is loaded successfully INFO | 2020-07-20 17:45:52,531 | 1 | 1 | 4844 | STA | UI Connectors | | | ExpressTranslatorService.ProjectAssemblyRefreshed() - Notified of assemby refresh. DEBUG | 2020-07-20 17:45:52,547 | 1 | 1 | 4844 | STA | Shell | | | Build state changing to Default DEBUG | 2020-07-20 17:45:52,578 | 1 | 1 | 4844 | STA | OSS | | | PackageServerClient.DeployPackageToServer: Executing request 'http:// Proprietary information hidden:5000/api/v1/packages/8D82CC0F33729AE/1.8'. ERROR | 2020-07-20 17:45:53,842 | 1 | 1 | 4844 | STA | OSS | | | PackageServerClient.DeployPackageToServer: Error uploading package to Package Server. ERROR | 2020-07-20 17:45:53,873 | 1 | 1 | 4844 | STA | Exception | | | Unable to connect to the remote server, Verbose Message: General Information
Diagnostic Info: Diagnostic.MachineName: CLTT282 Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e Diagnostic.AppDomainName: DefaultDomain Diagnostic.WindowsIdentity: RL\8027826 Diagnostic.ApplicationName: OpenSpan.Studio.Shell
Exception Information
1) Exception Information ********************************************* Exception Type: System.Net.WebException Status: ConnectFailure Response: NULL Message: "Unable to connect to the remote server" Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items TargetSite: System.IO.Stream GetRequestStream(System.Net.TransportContext ByRef) HelpLink: NULL Source: "System" HResult: -2146233079
StackTrace Information ********************************************* at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context) at System.Net.HttpWebRequest.GetRequestStream() at OpenSpan.Server.Clients.RESTTransfer.ExecuteUploadRequestToPackageServer(String url, String acceptType, String packageFileParamName, String packageFileName, Byte[] packageBinary, String configFileParamName, String configFileExtension, NameValueCollection configFiles, NameValueCollection configNames) at OpenSpan.Server.Client.Services.PackageServerClient.DeployPackageToServer(Byte[] packageBinary, NameValueCollection configFiles, NameValueCollection configNames, Exception& exception, String& errorMessage)
2) Exception Information ********************************************* Exception Type: System.Net.Sockets.SocketException ErrorCode: 10061 Message: "対象のコンピューターによって拒否されたため、接続できませんでした。 Proprietary information hidden:5000" SocketErrorCode: ConnectionRefused NativeErrorCode: 10061 Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items TargetSite: Void DoConnect(System.Net.EndPoint, System.Net.SocketAddress) HelpLink: NULL Source: "System" HResult: -2147467259
StackTrace Information ********************************************* at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) ERROR | 2020-07-20 17:45:53,889 | 1 | 1 | 4844 | STA | OSS | | | Error publishing package to Pega Server ERROR | 2020-07-20 17:45:53,904 | 1 | 1 | 4844 | STA | Exception | | | Unable to connect to the remote server, Verbose Message: General Information
1) Exception Information ********************************************* Exception Type: System.ApplicationException Message: "Unable to connect to the remote server" Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items TargetSite: Void PublishPackageToManagementConsole(System.String, Byte[], System.Collections.Generic.List`1[OpenSpan.Studio.Solution.DesignProject+DeploymentProfile], System.String) HelpLink: NULL Source: "OpenSpan.Studio" HResult: -2146232832
StackTrace Information ********************************************* at OpenSpan.Studio.Solution.DesignProject.PublishPackageToManagementConsole(String packageName, Byte[] packageData, List`1 profiles, String packageComment)
2) Exception Information ********************************************* Exception Type: System.Net.WebException Status: ConnectFailure Response: NULL Message: "Unable to connect to the remote server" Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items TargetSite: System.IO.Stream GetRequestStream(System.Net.TransportContext ByRef) HelpLink: NULL Source: "System" HResult: -2146233079
3) Exception Information ********************************************* Exception Type: System.Net.Sockets.SocketException ErrorCode: 10061 Message: "対象のコンピューターによって拒否されたため、接続できませんでした。 Proprietary information hidden:5000" SocketErrorCode: ConnectionRefused NativeErrorCode: 10061 Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items TargetSite: Void DoConnect(System.Net.EndPoint, System.Net.SocketAddress) HelpLink: NULL Source: "System" HResult: -2147467259
What could be the problem?
Another thing, the installation guide for PackageServer says the following:
Before you begin • If it is not already installed, install the Microsoft .NET Core 2.2.3 Runtime and Hosting Bundle for Windows. This software is included in the download. • If it is not already present, add the SSL certificate to the Local Machine, and place the certificate in either the Personal or Web Hosting certificate store.
I think since I am using plain http it should work fine even if I haven't added the SSL certificate, or am I wrong in here?
