Last activity: 26 Jan 2022 8:14 EST
Help on a Pega Academy question needed
Does any one knows the answer for
A data type organizes related data in an application and a ??? links the data to the system of record.
***Edited by Moderator Marissa to update Content Type from Discussion to Question; edited Title of post***
Likes (6)
Khushboo Bhattad Shobhandev Choubey Bhanu Prakash Reddy Simhadri T V M S N Sai Durga Pavan Pulavarti SURYA PRAKASH GODAVARTHI and 1 More -
Updated: 14 Sep 2020 9:20 EDT
CGI
Try 'data view'.
Maureen
Incessant Technologies Pvt.Ltd
A data type organizes related data in an application and a Integration Layer links the data to the system of record. Generally when we are fetching the data from external system data from external system will be mapped to integration layer and then to Data layer and then to application like cases.
Thanks for posting the query.
Data type represents the common data elements (For example Properties) which can be shared among the applications that were defined. If you define the data-type then in your work class you just need to create the page or page list property and just refer to this data-class and on expanding the created property in the work class, you can see the properties that were there in the data type.
A data type is nothing but a data class which stores the data in the dedicated table. If you check the test connectivity of the data class definition we can find that it points to the dedicated table. If you define the local storage for the data-type then you can add the data for the declared properties and it will create the Data-pages accordingly which you can find in the data-type.
Here the system of record refers to the data which was defined in the storage of the data-type.
CGI
Try 'data view'.
Maureen
Nirosha VIjayan DayaCTS Bongale Khushboo Bhattad sweta kumari NIHARIKA PALLI and 1 More
Thanx a lot :) It is the correct answer :)
Updated: 16 Aug 2020 10:37 EDT
Bank of America
A Data Type organizes related data in an application and a Data View links the data to the system of record.
Anirban Bhattacharyya DayaCTS Bongale SURYA PRAKASH GODAVARTHI
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-11/ea6437ef-8b28-4e21-aba0-53ee1b74c89f.jpeg?itok=lRzwknfp)
Rabobank
DayaCTS Bongale Pradeep Das sumalatha anduri Alison Pimentel Ganapuram shirisha
