CBA
Last activity: 9 May 2020 2:56 EDT
validation rules for checkbox
I have a requirement like when checking the RestrictDays checkbox it will display all weekdays. then the user without selecting any one day if click on the submit button. it throws an error message like a user must select at least one operational day. how will we write validation rules?
Please refer to attachment.
Updated: 9 May 2020 2:56 EDT
Evonsys
I just tried copying the link and pasting on browser and it worked even when I didn't login to collaborate.pega.com. Clicking on link was not working as you told. Could you please try again.
https://collaborate.pega.com/question/multiple-checkbox-validation-multiple-properties-it
Updated: 14 Jun 2021 7:38 EDT
Lloyds Technology Centre
Are those 7 weekdays are 7 different properties or using pagelist and repeating dynamic layout to populate them?
CBA
i have used all are individual properties and control type is true/false
Use a when the rule to check if all the 8 properties(including Restrict Days) are not true with AND condition, use this when rule in Validate rule.
Hi Sam,
Add disable condition on Weekends If Restricted is true then disable it.
Check for Weekdays in validate rule if restricted day is true
Check for all days in validate rule if restricted day is false
Hope this helps
CBA
Thanks for the reply, will it work for individual properties too
Evonsys
Since you confirmed you are using individual properties you can see approach mentioned in below post,
CBA
Thanks for the reply, Link is not working
Evonsys
CBA
Thanks for the reply, https://collaborate.pega.com/question/multiple-checkbox-validation-multiple-properties-it
