Starting a skin from a custom set of CSS files
Pega Platform 8.x
I have heard individuals speak of this but have no concrete example to work from/with.
I am building a Pega application. A CSS guru has created multiple CSS' for me to use and save me from having to build/modify the Pega skin structures. It's not that I don't want to do the work in Pega skin configurations but this CSS guru can make changes faster than me. So, I want to leverage that.
So,
1. How can I make this CSS list the parent skin within Pega?
2. If I have to use a Pega skin as a parent skin and then use my application skin with the CSS' as included styles, what is the most minimal OOTB Pega skin to use to minimize the deletion/override of the OOTB styles ?
3. As I am still learning Pega Skins/CSS, are there any other options that I am not aware of to solve this problem?
In all of these options, I want to be able to select the style(s) for the CSS' definitions within the UI control presentation tab; for ex. Instead of selecting strong, we may want to select primary (as primary is defined within the custom CSS')
thank you,
Rob
