Telstra
Last activity: 8 Feb 2021 10:16 EST
Pega Robotics Runtime Windows 10 1909 Support
Could you please let me know whether the Pega Robotics Runtime is compatible with win 10 1909?
If yes, please help with the version no.
Prashant
aaseya
SA
As per the below discussion, Pega 8.0 sp1 is compatible with Windows 10 build 1903,
OS Windows 10 build 1903 is one of the minimum requirement as per the below instructions.
I think Windows 10 1909 should also be compatible.
https://collaborate.pega.com/question/pega-runtime-802030-windows-10-build-1903
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-05/1f77a272-b558-4261-964a-0a7d028c27c5.jpg?h=436c2321&itok=Ilx-4hBN)
Version 19.1 supports Windows 10 1909. Windows support is determined by the version of Pega Native Foundation installed. We always recommend you install the latest version.
The Pega Native Foundation version that is compatible with version 19.1 is the PNF 10.1 series. The last digit of the version number is the latest Windows version supported. So version Proprietary information hidden9 - Proprietary information hidden9 all support Windows 10 1909 and our recommended version for you to use is Proprietary information hidden9.
Updated: 5 Feb 2021 1:58 EST
Standard Chartered Bank
We are currently using Pega Robot Studio and Runtime Proprietary information hidden and this year we will be rolling out Windows 1909
That means we can upgrade to latest version of PNF in all end users machines where runtime is installed or first we need to upgrade PNF on development machines perform a test run followed by rebuilding and redeploying the solution back to end users machine provided they have upgraded PNF.
Please confirm if my understanding is correct.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-05/e90c12b7-5a50-45b6-9408-8644c06fabca.jpg?h=9bedb0c7&itok=I_lzpbin)
@AdityaS02 That is correct. Upgrade your PNF and test before you rollout. Ideally you'd upgrade Runtime/Studio to a later version as well given that 19.1.12 was released in September of 2019, but PNF is a separate installation and can be updated independently of Runtime/Studio should you not want to change anything else. I don't believe you can download PNF by itself though as it is usually delivered with the Runtime installation. When you request the download, just grab the latest Runtime version available and the PNF installation will come inside the ZIP file.
Is the support for automating 32bit application is a part of windows 10 ver 2004 or 1909 ?
@AdityaS02 I am not certain what the Windows update supports as that would be a question for Microsoft, but the PNF version supports 32 and 64-bit applications.
