PE - Cassandra is not working.
Decision Data Store Node not showing.
Node settings can ben viewed.
How to make it work?
Problem solved:
Change "setenv" batch file in Tomcat/bin
Set JAVA_OPTS=%JAVE_OPTS% -DNodeType=Universal
All is working now!
You should have one node type(-DNodeType) as DDS ,how many nodes you have in the environment .
What are all the node types you have configured.
I use the personal edition 8.4 on Windows 10 with one node. The DDS node does not show even the setting seems to be correct. I have a node in Streams.
Problem solved:
All is working now!
Support Doc
