unable to save the document in the desired folder location using PEGA RPA
Our use case is to save and rename the document from the browser.
But, whenever i run the automation, its saving the file in the last download folder location and also not renaming the file.
I am passing the path as a text parameter using string concat to the text field in the Save As window. The path(text) is getting changed with new the path (text) in the text field of Save As window. But when bot hits on Save button, file is not getting saved in the new path.
There is no Raise Event method that I can use for this control. Tried with Tab out, still did not resolve issue. Anyone, please let me know how to fix this issue.
Thanks in advance.
***Edited by Moderator Marissa to change type from Pega Academy to Product***
