Capgemini India PVT Ltd
Display Pagelist In its data class
HI
I have requirement where i need to display a pagelist. I have create a section in Data-Pagelist. I have to display the pagelist in section(Data-pagelist).
Updated: 14 Jun 2021 7:38 EDT
It seems to be a problem with your section's class.
The section is in the Data class and Itemslist pagelist is under the work page.
Either use "pyWorkPage.ItemsList" in List/Group and declare pyWorkPage in Pages and Classes or save the section in the work class.
You can use Table layout or Repeating dynamic layout and give the souce as clipboard page(pagelist).
In source there are three (table Layout)
1. property
2. data page
3. Report definition
Help me what to mention and how to mention clipboard pagelist
You can select property and give the property name.
I have used table layout and in source tab i mentioned a pagelist
and edited the tab with my required columns
but not displayed while running the code
Could you please check if the pagelist is there in the clipboard and please share screenshots if possible.
Updated: 20 Mar 2020 9:15 EDT
I have a senario where i have page list (Items List) which is input from user. Then next step i'm using split for each. the page list (Products) i'm using is filtered one from ItemsList. To remoove repeated process.
Then in each process i need to display initial pagelist (Items list) based on condition i.e vendor (each process is upon vendor selection) respective vendor data should be visible to respective vendor.
If you want to display ItemList pagelist in a table, you can use the ItemList as a pagelist and check if each page inside the pagelist has values.
Yeah I did the same thing
i used table layout and mentioned the itemslist.
But not able to display it. Pagelist has values in clipboard.
Could you please share the screenshots of the section and see if ItemsList(1) has values.
Here are the screenshots of configuration of section
Gugulothu Surya
ThankYou so much.
That was helpful....
I have another doubt. How to show row when a particular vendor is selected. So that respective data is showed from ItemList pagelist.
eg. if car@capg is selected respective data is need to visible from pagelist
Tell me the conditions usage of grid visibility,Row visibility, Row fresh.
Visible row when pyworkpage.itemlist.vendor equals products.vendor ??
suggest me in when rule
Please find the below screenshot for when rule.
Gugulothu Surya
Says Invalid Expression
I have two pagelist of same type
i.e Itemlist(itemlist) and products(itemlist)
so i need to compare these two clipboard pages and need to apply visible row when vendor on each page is same.
In the section "ProductsQuote" how are you displaying Vendor, similarly you can use in when rule.
Thank you.
It is resolved
