First drop down value not passed as parameter to next 2 drop downs
Ii section 4 drop downs inside table,when ever we change the 1st drop down need to refresh the current row and enable next 2 drop downs with values passed 1st drop down value as parameter.
2nd and 3rd dropdown source as Datapage with load management as PerEachInteraction. Onchange of 1st property all corresponding datapage's called bacause of RefreshCurrentRow in 1st property Actions and next 2 drop down's enable with values.
Dp's called 2 times here
RefreshCurrentRow : 1st time DP's called with parameter passed values After enable 2 dropdown's : again 2 dp's again loaded but parameter not passed for DP's
Pls suggest.
