Putumbaka
Last activity: 20 Feb 2020 6:19 EST
Work Object assignment and flow actions displayed
I have a requirement to transfer work object to another operator. We have defined that on the assignment shape by giving the worklist name. Now the flow actions coming out of this assignment shape should be visible to the previous operator. But as case was transferred in assignment shape and then flow actions are called, flow actions are showing up on the actions button of the second operator to whom the case was transfterred. but our requirement is to display flow actions under actions button for the first operator.
How to achieve this ?
Updated: 20 Feb 2020 6:19 EST
Putumbaka
Got the solution We used Perform privileage for the flow class
FR
Usually a transfer or a reassign is done within a local action not a flow action. Can you use a local action instead of a flow action?
Putumbaka
We used assignment shape to route the work object
Putumbaka
Any other suggestions?
Inovar
LK
A flow action represents an available action at the flow assignment which can be performed by the user. If the associated flow actions are to be performed by the previous user, then the assignment should be in the same user's list, and the reassignment needs to happen once an appropriate action has been taken.
Putumbaka
any way that we can modify this functionality for one flow?
Updated: 14 Jun 2021 7:38 EDT
Where did you configure to show Flow action to show under the Actions menu?
1) In the case type rule as Case wide actions.
2) In the action menu navigation rule as menu item.
Putumbaka
Action menu navigation rule as menu item
Putumbaka
Brendan Horan Bhargav Putumbaka
