Change events on Grid repeat
Hi!
Is there a way to add a "change event" on Grid Repeat Layout?
I want to refresh another section when Grid Repeat has changed, but in action set tab I cant choose change event (it is just not showing - see possible action set png)
I tried to put my grid repeat layout inside dynamic layout and to use change event on main dynamic layout, but it is not working
So, my questions is, is there a way to refresh another section, when Grid repeat has changed?
(I also tried to add postprocessing activity with call ReloadSection, but it is only update back-end part and don`t actually update UI)
If you are grid is sourced with DataPage or list.
Embed the section you want to refresh in a dynamic layout and you have a refresh condition to refresh the layout (check screenshot). In which you can use, either DataPage change or list changes. So whenever a row is added/removed from the grid, the respective Page or list will be updated and refresh will be performed on the embedded section.
