Ashoka Istitutions
Last activity: 28 Jan 2020 15:38 EST
How to create a Data Table in Pega 7.4.0?.
I tried creating a Data Table in Pega 7.4.0. I went to Designer Studio -> Data model -> Data Tables -> Data Tables.
I don't see Create a New Data Table option here. It says, " Data Tables have been replaced by the new local data storage format. Please click 'Convert' on each data table to convert them into the new format. To create storage for a new data type, go to the Data Explorer. ".
I found these steps online:
Configuring local data storage
Local data storage lets you store data records for a data type without having to manually create or maintain database tables. Local data storage is used with a data type's record editor. Access local data storage on the Sources tab for the data type in the Data Designer.
Use the Local Data Storage wizard to create a local data source:
- Click Data in the Data Explorer.
- Click the data type.
- Click Sources.
- Click Create a local source.
- Configure the source for the record editor to use.
- Review local data storage properties.
- Once the wizard finishes, you may see a warning that the system could not generate a dedicated database table for this data type. Refer to Fixing database table generation for more information.
But I don't see anything called Data in the left panel, I see Data types in the left panel.
Went into the Data types option and tried to create a new data type, by doing, Data types -> click on the down arrow beside Data types, -> click on Add data type option available in the drop down.
But then I was thinking that, this data type and data table may not be the same one.
so I didn't create any data types.
Can anyone guide me creating a new data table in Pega 7.4.0?.
Please and thanks in advance.
Best Regards,
Sai..
