Lloyds Banking Group PLC
Last activity: 9 Dec 2019 3:29 EST
Behavior of a string property with value set from a double property
v7.3.1
We connect to an API which returns a numerical value and the integration wizard has generated a double property for this attribute. We have a String property in the application which will now be set with the value from this integration response property (of data type double).
Behavior based on the tests I have done so far -
Integration property value (double) - 12345
Application property value (string) - 12345.0
Integration property value (double) - 1234567
Application property value (string) - 1234567.0
Integration property value (double) - 12345678
Application property value (string) - 12345678
If the value for the double property is between -9999999 to 9999999, the String property has a decimal point added to it as mentioned above in the examples.
Question:
Can anyone explain this behavior please?
