Screen Flow Tab Navigation to Stage View
Is there any OOTB to convert the tabbed View of the Screen flow to Display stage kind of UI?
Is there any OOTB to achive screen flow in below format
Hi Chandan,
I believe there is no OOTB way to convert the tabbed View of the Screen flow to Display stage kind of UI. You could probably change the UI as per your requirement manually.
I might be wrong but I don't think there is no. So you could either change your screen flow to use a normal flow with stages or you could change the UI representation of your screen flow to present stages like pictures.
