Credentials to login to app studio is not correct !
from where can I get the right credentials?
user : root
pass: install
user : root
pass: install
Login credentials should be provided with each exercise in a course. The credentials should be posted at the beginning of the exercise, immediately following the scenario.
If you notice that an exercise is missing login credentials, please notify us with the course name and exercise name.
root / install is the set of credentials for the operating system that hosts the application server. Credentials for performing a specific exercise are provided at the beginning of each exercise.
I have the same issue. Can you please advise? Login credentials were not provided throughout the course
