Asurion
Last activity: 26 Nov 2019 9:45 EST
How to enable Oracle JDBC logging in tomcat
Hi ,
we see connectivity issues to database from app server. the issue is sporadic and affect only one node in multi node cluster and it recovers it self after sometime. we have ruled out DB issues and network issues as it affects only one node for a period of time, when other nodes operates normally.. I wanted to enable ojdbc logging and see if I can get clue for this issue.
I have downloaded the oracle jdbc7_g .jar and replaced the jdbc.jar in tomcat lib and made the below changes.
Created config.properties for logging with below setting
ava.util.logging.FileHandler.pattern = /usr/share/tomcat7/logs/jdbc.log
java.util.logging.FileHandler.limit = 50000
java.util.logging.FileHandler.count = 1
java.util.logging.FileHandler.formatter = java.util.logging.SimpleFormatter
handlers = java.util.logging.ConsoleHandler
java.util.logging.ConsoleHandler.level = ALL
java.util.logging.ConsoleHandler.formatter = java.util.logging.SimpleFormatter
oracle.jdbc.connector.level = FINE
oracle.jdbc.driver.level = FINEST
oracle.jdbc.internal.level = FINE
#oracle.jdbc.oci.level = FINE
#oracle.jdbc.oracore.level = FINE
oracle.jdbc.pool.level = FINE
#oracle.jdbc.rowset.level = FINE
oracle.jdbc.util.level = FINE
#oracle.jdbc.xa.level = FINE
oracle.jdbc.xa.client.level = FINE
#oracle.jpub.level = FINE
#oracle.net.ns.level = TRACE_20
Hi ,
#oracle.sql.level = FINE
Enabled oracle debug logging in tomcat7.conf in Catalina_opts
-Doracle.jdbc.Trace=true -Djava.util.logging.config.file=/usr/share/tomcat7/conf/myConfig.properties
i'm using tomcat 7
but still i'm not seeing the debug logs.. can anyone please let me know if I'm missing anything.
Nagendran Arumugam
