CenturyLink
CenturyLink
CenturyLink
Posted: Nov 7, 2019
Last activity: Nov 12, 2019
Last activity: 12 Nov 2019 15:03 EST
Pega.Loader.exe - How to disable splash screen
Can anyone help answer the following? This is regarding Pega Robotics 19.1.11 with Sync Engine.
- Is there a way to disable the splash screen when launching Pega.Loader.exe? In our production 8.0 SP1 robotic runtime deployement, we are currently disabling the runtime splash screen in OpenSpan.Runtime.exe.config under <SplashScreen> and setting enabled value="false". As we continue to pilot 19.1, we are looking for a way to do the same.
- Is there a valid list of command line parameters for Pega.Loader.exe? There are a couple of parameters listed here (https://community.pega.com/knowledgebase/articles/pega-robotic-automation/what-startup-parameters-can-i-use-pega-robot-runtime). We confirmed that (--args Project="path") is not accurate and does not work for loading a project. We were able to get the correct parameter for loading a project (-d "path") from a Pega developer who was onsite recently. It would be nice to have a complete parameter list that is accurate if it exists.
Brian.
