New South Wales State Government
Last activity: 17 Oct 2019 3:13 EDT
Issue while creating custom cipher in Pega Platform
I need to create custom cipher in Pega Platform. I followed the below link
https://community.pega.com/knowledgebase/articles/security/creating-custom-cipher-pega-platform
From the scripts directory, ran runPega.bat with the following parameters:
--driver <path to the database driver file>
--prweb <path to the archives/prweb folder>
--propfile <path to the bootstrap properties file>
com.pega.pegarules.exec.internal.util.crypto.JCECapabilities
but facing below issue
'#check' is not recognized as an internal or external command, operable program or batch file.
Error: Could not find or load main class com.pega.pegarules.pub.PegaRULES
Problem:
com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'PegaDATA.pr_data_admin'.
Do you have below config in prconfig.xml?
com.pega.pegarules.bootstrap.datatables.schema=PRPC7311DATA
hi,
can you please check if prbootstrap.properties file is updated to the correct codeset version for your Pega platform??
com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode=07-xx-xx
Yes setha, com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode is updated to the correct codeset version
com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode=07-10-33
Please try what I have suggested below, it will solve your issue
Can you open runPega.bat or runPega.sh and update the below line with correct version of the jar you have in the system.
set classpath=%classpath%;%warDir%\WEB-INF\lib\jsr94-1.0.jar;%warDir%\WEB-INF\lib\prbootstrap-api.jar;%warDir%\WEB-INF\lib\prbootstrap.jar;%warDir%\WEB-INF\lib\prdbcp.jar
NOTE: The above line may be different based on Pega version you have
In 7.3.1
In Pega 8.1
You can also try below and see if it works
set classpath=%classpath%;%warDir%\WEB-INF\lib\*
Also there has been different issues identified in the below post. May help you
In 7.3.1
In Pega 8.1
Thank You
I have attached the file with the changes I have made. You can refer them
You may or may not pass code version, both will work. Please refer the attached file and modification.
Major one is what I suggested above
I have added run logs as well.
Thank You
Thanks Shekhar, after updating classpath in runPega.bat to the correct jar file names and commenting out the line '#check if ...' in runPega.bat solved the current issue.
Cross check the prbootstap.properties and prconfig.xml which I have attached. Now the issue is only with finding the file and loading the setting.
Verify what values you are passing and how I have passed them
Thanks Shekhar, the command is working now. I missed database Name in the url in prbootstrap.properties file. All good now.
Thanks again !
Problem:
Thanks again !
