Aaseya IT Services Pvt Ltd
Last activity: 27 Jan 2020 10:22 EST
The Specified winHLLAPI function could not be found in WinHLLAPI dll
Not able to run the solution in runtime on test machine, package loading is completed but when tried to run the package its unable to launch mainframe/BosaNOVA emulator.
Solution is absolutely fine on the Prod/Dev machine, checked with loading the package in local runtime (openspanruntime.exe from Visual studio folder)
Robot is starting from the run time as well but not able to start Text Adapter from dll, To launch the text adapter/mainframe, i'm using BSHLL32.dll
All the mcafee events immediately following or preceding the execution of the dll or the runtime are phrased the same, no notion of blockage/ access issue.
