Cognizant Technology Solutions India PVT Ltd
Last activity: 19 Sep 2019 6:29 EDT
Can we run VB Script (.vbs) code in Automation? If Yes, how that is?
As per my requirement need to use vb script. I tried to achieve with C# script but not found the solution.I got lot of vb script (extension with .vbs file)code solutions in google So, i want to utilize those script in my automation as reusable ones.If possible to run in Pega Robotic Studio, please tell me how to do so.
Thanks in Advance,
Gururaja.
The below link might help you.
https://collaborate.pega.com/question/using-vb-language-scripts-contructs
https://collaborate.pega.com/question/writing-vbnet
https://collaborate.pega.com/question/calling-batch-file-or-script-automation
Thank You,
Infosys
Check the code here:
https://collaborate.pega.com/question/it-possible-run-vba-script-openspan
Thanks for your response.
I don't want to use VB.NET code. Want to use VB Script code which we can write in notepad/nodepad++ and save with extension of .vbs
Find the attached zip file (open it.zip) which contains vbscript file (Sample Date.vbs) for your reference. Can execute the code by double clicking on Sample Date.vbs script.
Infosys
You want to execute .vbs file by double click from the automation?
Previous attached link explain how to execute .vbs file from automaton using c# script.
Thanks Jayachandra for giving solution.
I can run the simple parameterless code only, i can't pass parameters from c# to Vbscript and return the value from vbscript to c# method.
I tried to pass parameters as below
process.StartInfo.Arguments = <firstvar> + "<space>" + <secondvar>;
and dont know how to assign returned value from vbscript to c# variable.
Infosys
Check this link
https://stackoverflow.com/questions/2992164/question-on-returning-values-from-vbscript-to-net
I could not found how they passed input parameters and returning output value from Vbscript through c#.
can you tell me what are the input and output parameters in below code;
var p = new Process()
StartInfo = new ProcessStartInfo("netstat")
RedirectStandardOutput = true,
RedirectStandardError = true,
UseShellExecute = false,
var outputWriter = new StringWriter();
p.OutputDataReceived += (sender, args) => outputWriter.WriteLine(args.Data);
var errorWriter = new StringWriter();
p.ErrorDataReceived += (sender, args) => errorWriter.WriteLine(args.Data);
p.Start();
p.BeginOutputReadLine();
p.BeginErrorReadLine();
p.WaitForExit();
if (p.ExitCode == 0)
Console.WriteLine(outputWriter.GetStringBuilder().ToString());
else
Console.WriteLine("Process failed with error code {0}\nMessage Was:\n{1}", p.ExitCode
, errorWriter.GetStringBuilder().ToString());
