Popover containers top position misalignment
For some reason all the popover containers (i.e. auto complete drop values, date control picker, smarttip) have incorrect top position and shows up a gap between the click position and display position (screenshot attached).
This only happens when I setup the enterprise skin as hierarchy to the application skin, if I set up hierarchy as pyEndUser it all works fine but not when I use customer enterprise skin. I don't know what is causing this issue in the enterprise skin.
If I launch the application inside designer studio or view the smartip inside skin preview mode it all works fine the issue is only when I launch outside studio.
Appreciate if anyone share ideas or solution if you have come across this issue ?
