Blue Cross Blue Shield of MA
Last activity: 5 Sep 2019 15:33 EDT
Best Practice for embedding Javascript UI Frameworks
Wanted to ask if we are going against Pega Best Practice for UI, or otherwise violating any support contracts in place if we build custom HTML rules to use Javascript frameworks such as AngularJS / NodeJS / etc.
The question is not about whether things will work - I'm sure we can make anything work. Question is does Pega endorse this approach for UI reuse,
OR
Does Pega recommend we build all UI consumed from PEGA portal to application users using PEGA rules meant for that purpose.
Trying to avoid situation where if we end up reusing UI widgets using some Javascript framework, by embedding within some harness, and then finding out later PEGA does not really support such reuse.
