Clone/Copy Pega Database
Writing up my experience on cloning the Pega database.
Having done a quick search of the community site, it doesn't seem there are postings regarding the topic of "cloning" the Pega database.
Cloning the database, or taking a "full snapshot/backup" of an existing instance and porting it over to a new database instance may save time as well as ensure *everything* has been copied/moved over.
Consideration:
- the target database ideally should be of the same database software and version as the source.
- use database tool of choice to perform a complete clone/copy of the schemas, such as "rules" and "data" schemas, if using split-schema Pega configuration
- use database tool of choice to import the data into the new target database instance, with schemas intact
- validate the target database user, roles, permissions are set according to the Pega installation guides
- update the tables <data_schema>.pr_data_admin and <data_schema>.pr_sys_statusnodes to remove references to the prior nodes
- adjust application server connectivity to target database (if necessary)
- start up application server and login to Pega (with credentials from prior instance).
- validate the system to ensure the code base is intact
- Done!
This process has worked with Oracle and SQL Server installations, and as of today, it has also worked for migrating from Azure SQL "standalone" / "singleton" to Azure SQL Managed Instance.
Good luck.
***Edited by Moderator: Lochan to convert post to discussion and tag as developer knowledge share***
