Running BIX from command line causing issues to stream nodes
Whenever I am running .sh file which contains code to execute BIX from command line, it is impacting Stream nodes and Queue processors are getting stopped.
also in logs I can see that the process tries to start Stream server but as this node is no where related to Stream but it caused issue in production and then we had to disable BIX node as a rollback plan.
Please let me know if someone has some idea on this.
Attaching documents,
Logs(PegaRULES.txt)
