Screen Flow Navigation with Sub Processes
Issue Summary:
Platform is Pega 8.1.5
I have a large process that I want to break up into more reuseable parts. I need to be able to combine these into screen flows for use in different stages. Looking at the documentation I have found this is supported as long as the sub flows are also screen flows.
I am not using breadcrumbs in the UI.
The issue I have found is that the 'Back' navigation button is not working on the assignment directly following a subflow. It is taking the user back to the last assignment in the current flow not the last one of the sub flow.
Question:
Is there an easy way to stop this / some configuration I have missed? I want the behaviour to be the same as if all of the assignments are in the same screen flow.
