Passivation mechanism with Pega 8
In Pega 5 - 7, there was a functionality called "Passivation" that is triggered by user requestor's timeouts. The clipboard data on memory was saved into a file in "PassivationData" directory under temp.
However I am not seeing such files / directory in my local Pega 8 environment. I used to be able to check actual passivated data by SMA but in Pega 8 SMA is even not found.
#1. Is Passivation functionality still in-place?
#2. How can I check the passivated data if SMA is deprecated?
